Page 1 of 3
starting a TV 15-32 in SC
Posted: Fri Mar 28, 2014 6:27 pm
by grayduck
Just got my plans and have started cutting patterns out of sublinoleum ply since I have a 16 x 4 marine ply I had already scarfed and glued for other project. I built a Cajun secret and its a nice piro. I just liked what I read and saw with the TV. Ron's posts were major influence. Hope I can do has good a job. Bill
Re: starting a TV 15-32 in SC
Posted: Mon Apr 07, 2014 9:29 am
by grayduck
using ply patterns seemed easier way to get measurements right on the 4x16' piece. And I got all panels from just two sheets.
cut out
4x16 sheet
had to glue up one of the small panels but the other 5 are full length
Posted: Mon Apr 07, 2014 6:57 pm
by tw541
I'm looking forward to seeing this build. I have long considered the TV, and will probably build one after I finish what I am working on now. I have the plans for both sizes of the TV.
Posted: Tue Apr 08, 2014 11:38 am
by grayduck
The frames are all loosely attached now. I was thinking of putting two 2x4s along the tops of the frames so I can flip it over at this point to tighten and trim the fit before putting on the second set of panels. A backwards strongback I guess. Any potential issues with doing that? ie are the tops of the frames supposed to be in the same plane? I realize it could affect rocker but I will be able to take them off when putting on the second set of panels which really set the rocker at that point.
Posted: Wed Apr 09, 2014 8:47 am
by grayduck
flipped over on temp strongback
this made it easier to tighten frames to bottom. I realize I need the easy button more these days...
flipped back with sides starting to go on.
the aha moment when it starts to look like a boat!
Posted: Thu May 01, 2014 8:57 am
by grayduck
progress pic
Posted: Thu May 01, 2014 12:49 pm
by DCRICE
Very nice. I may do a TV this fall.
Posted: Tue May 06, 2014 4:54 pm
Looking good Duck.
Posted: Wed May 07, 2014 6:08 am
Nice, clean work.
Posted: Thu May 08, 2014 8:45 am
by grayduck
Thanks guys. I am enjoying this build very much but have had a lot of other projects going on.
Put cloth on outside yesterday
and applied first coat
Boat is starting to look bigger...
One question I have is if you put fore and aft decks on, how should you make the transition of outside rubrail (at the gunnel height)? just start and end at the decks? I have not seen anyone go all the way from bow to stern but maybe I missed it. and what size should it be? thanks
