Bad epoxy mix
Posted: Wed May 30, 2012 10:39 am
by echo5000
I didn't put enough hardener in my last batch and its still a little sticky to the touch after 24 hours, what are some recommended solutions...? Of course there are bugs that like to land on the shiny surface...
Thanks,
Jon
Re: Bad epoxy mix
Posted: Wed May 30, 2012 2:48 pm
if possible, get it in the sunlight or spot where it can be warmed up some. Check it again after another 24 hours. If still sticky, you'll have to scrape it off.
Re: Bad epoxy mix
Posted: Thu May 31, 2012 3:42 pm
by echo5000
It cured up nicely, thank you.
