Hi Matt I have just finish cutting my plywood for my okky , when i purchased my plans from you i ordered plans with the small cockpit size, ie. 18"x33" I am thinking due to my mobility, or
"'lack of it" that i would be better off with the larger cockpit ie, 18"x40" .My questions are ,
do i just cut it out to the larger size ,? do the permanent bulkheads need to be repositioned?
any other requirements to take into consideration?
looking forward to your reply
regards Ray (Cridgie down under)
okwata 15 cockpit size
Re: okwata 15 cockpit size
you can just cut to a larger size. Assemble the full length deck panel and use that as a pattern to for the coaming pieces.
