PiratePete
Posts: 305 Joined: Fri Sep 11, 2009 6:57 am
Post
by PiratePete » Fri Oct 23, 2009 9:12 pm
Hi Matt
What are the specs on Scottrunnr's 12' SOT.
That seems to be the size that best suits the water I hope to fish in.
I would like to build one first & then see how it goes.
Maybe then look at fitting a Mirage Drive to that or then maybe go fir a Wadefish.
Posts: 4916 Joined: Fri Jun 18, 2004 8:14 pm
Post
by jem » Sat Oct 24, 2009 9:03 am
I'll post up some info on that design later this weekend.
It's design is similar to the Wadefish which has gotten some less-than-favorable info posted about it (which was a result of me not being clear enough about the design). So I'll put together some specs that clearly state what the expectations of the hull can be.
PiratePete
Post
by PiratePete » Sat Oct 24, 2009 6:09 pm
Cool
Thanks Matt.
I hope to use it in some smaller rivers here & the 12' will do it more easily than a 15'
As I said above I may not fit a Mirage drive to it first off.
Pete
PiratePete
Post
by PiratePete » Mon Nov 02, 2009 12:06 am
Hi Matt
How did you go with the specs etc for the Blue Fin ???
