Laker 13 with dash and new paddle
Posted: Sun Jul 19, 2009 8:54 am
Some time ago I decided the Onkalaker needed a dashboard and put one together. Today I finally tested it on the water with full fishing kit and new paddle.
The dash looks very low at the cockpit opening and it does take some wriggling to get past it - but only a bit. The height allows my knees to brace up against it for better control while paddling so overall it has worked out quite well.
I took a rod/reel, a bag of tackle, knife, cutters, pliers, rag, first aid kit and camera within reach, and a spare single blade paddle in the rear bulkhead. Even with all this (and the dash) attached I could lift the whole thing and put it in the water without any strains.
There are several tie on points inside the cockpit and the shock cord that holds the dash in place made great holders for the knife and pliers. Didn't plan it that way but I'm happy with the result. The rod butt goes under the shock cord on the dash when paddling and is held surprisingly firmly but is also easy to get out. Leashes were used to tether the camera, rag, pliers and paddle and the tackle bag strap was looped through a tie on point.
The seat is home made and turned out to be comfortable and sturdy
Unfortunately the wind was surprisingly strong so I didn't try too much fishing. The photos don't show it but the last section heading home was a struggle - the wind was much stronger than my previous trip.
