Ultralight Sasquatch 14
Posted: Sat Feb 07, 2009 9:59 pm
by Bobmas412
I see on the Sasquatch 14 plan that it is possible to build the canoe ultralight by using 3 mm (instead of 4 mm) plywood and 4 oz fiberglass (instead of 6 oz). Does anyone have experience with a canoe built like that? I would prefer ultralight and would be pretty careful in it's handling and use, but on the other hand I don't want it to be "flimsy". What about 4 mm plywood and 4 oz fiberglass? Would that be a little tougher?? Thanks in advance for answers// Bob
Re: Ultralight Sasquatch 14
Posted: Sun Feb 08, 2009 12:50 am
by Jimmy W
Posted: Sun Feb 08, 2009 8:33 am
Since the Sasquatch has multi panels, you can use 3mm and have a study hull. That's what Chuck used in the above mentioned thread.
Posted: Sun Feb 08, 2009 9:20 am
Besides being light ( 30 pounds) it is quite strong and not flimsy at all. I would rate it as very solid , as solid as any manufactured glass canoe I have ever had. It's just a ton lighter and nicer then any of them.
If you are around the central Florida area and want to check it out , give me a holler.
Posted: Sun Feb 08, 2009 3:33 pm
