Question No 1 - and I'm sorry if this is in the instructions
I imagine the deck is not as critical as some other areas but having a tolerance to work within will give confidence that I'm being accurate enough without wasting time being too finicky.
I've settled for an exterior ply, ordered on spec, but am not very impressed with it. It is marketed as hardwood but the back appears to be pine and the exterior veneers are very thin. I am confident it will still make a reasonable boat but it will cost some time in needing TLC. Density is not too bad - worked it out to about .44 specific gravity (somewhere between quoted figures for Gaboon and Hoop pine).
Time to go and work on question 2 now.....
