I chose this boat as a simpler build to test my theory that you can build using cedar and pine strips from just about any plan. Also, I have an abundance of cedar and pine. It is more labor intensive and takes longer to build than plywood, but is much quicker than building a cedar strip boat using the taditional method of forms and a strongback. Also, there are no vertical seams and no need to find expensive plywood. However, the boat probably is not as strong as a plywood boat. Therefore, I uses a layer of 6 oz on the bottom of the hull along with a layer of 4 oz cloth on the bottom and outer sides. Six oz completely covers the interior.
Here I am preparing to take my current youngest for his first boat ride. If you notice there is no wedding ring on my left had, its because it's in the bottom of the lake somewhere. The wooden thing hanging of the back is what the transducer is mounted on. I made it to be adjustable in depth so it can be used with both my cedar strip kayak and the pirogue.
Here we are heading out
Lots of fish on the fish finder but none ever made it into the boat.
Here we are coming back to shore. And no, its not a white t shirt I'm wearing, I just don't get in the sun much!
And to top it off, we had a beautiful sunset.
The plans were easy to build from and I enjoyed it (except for the sanding). Thanks Matt. I hope you don't mind me deviating a little from your plans
ps, It also tracks like a dream .
