1. I see in other threads that porch paint is acceptable which is great because 10 bucks a quart compared to 36 bucks a quart will pass by the accountant a bit easier.
I found Valspar and they have both oil and latex; which one? Or does it not matter.
2. Is priming neccessary or will a 220 grit (Or coarser?) rub down do the trick to stick it to the epoxy?
I will still be hitting it with Z-Spar also.
Wayne
