Flotation
Flotation
I am building an 18 foot, 24 inch wide stich and glue rowing shell with enclosed decks that uses a Piantesosi drop in sliding seat unit. I want to pus some kind of flotation in the sealed off sections of the hull for and aft. I also like the idea of having a "solid" hull in case I hole the boat on a frequently encountered submerged stump. I have been thinking of layering some kind of closed cell spray foam like the kind builders use - "Great-Stuff" is one name brand. I know to be cautious of the foams expansion pressure deforming the hull as I blew out a bulkhead in a fiberglass version of a guideboat I built years ago.... Any thoughts/suggestions? Thanks Charlie
