dk canoe
Posted: Sun May 18, 2008 4:03 pm
by fishforfun
Ok i have used but blocks on my splices. Can I put the fiberglass patch just on the opposite side of the panel and just leave the but block bare intill i glass the inside of canoe i am glassing inside and out or do i have to patch bothe sides? I was figuring that when i glass inside that would strenghten up the area.
Re: dk canoe
Posted: Sun May 18, 2008 4:09 pm
fishforfun wrote:Ok i have used but blocks on my splices. Can I put the fiberglass patch just on the opposite side of the panel and just leave the but block bare intill i glass the inside of canoe i am glassing inside and out or do i have to patch bothe sides? I was figuring that when i glass inside that would strenghten up the area.
If you did the wooden butt block properly, you don't need a fiberglass patch on the other side of the panel seam.
Posted: Sun Jun 01, 2008 10:56 pm
by fishforfun
I'm haveing a problem in getting any ash or maple that will work for gunwalls all of the saw mills are not careing any due to the restrictions on the emerald ash bore. My ? is can i use spruce for the gunwalls if i coat them with fiberglass resin?
