tack welding
Posted: Sun Apr 01, 2007 8:54 am
by sawdusty
Finally moving on to the epoxying stages of the boat. Raka sent my goo to my old address and it took about 2 weeks to get. Honest mistake.
I was wondering if any of you all have tried this. I mixed up my thickened epoxy for tacking everything together, then put it in a ziploc bag, cut the corner off, then filled the gap squeezing it like a pastry bag. I did it both ways and found the patry bag method to be quicker and easier. Plus I felt like I was filling the gap more consistantly. Then I went back and only had minor touch up with the putty knife. I did find that the thinner bags can burst.
Anyway, it seemed to work for me.
Moving on.... :D
Posted: Sun Apr 01, 2007 9:34 am
I've done it that way before and it works pretty good.
Posted: Sun Apr 01, 2007 10:33 am
Heya Sawdusty,
That is exactly what I do. Quick, clean and very little waste.
Posted: Sun Apr 01, 2007 6:06 pm
by popeye
I have taken to using empty caulking type tubes. You can buy them for about a $1.50 ea. The work excellent but there is a little wast left in the "nozzle" but you can push that out with a dowel.
http://i111.photobucket.com/albums/n122 ... es_200.jpg
Posted: Thu Apr 12, 2007 7:55 am
by surfman
Yea the hard part was getting the goo into the bag. I use a "freezer" zip lock bag and clamped it to the boat holding the bag open for easy spooning of the goo into the bag.
Posted: Thu Apr 12, 2007 8:03 am
I've gotten to the point where I just use a wooden craft stick to apply filleting material.
First, I mask off each seam like shown above.
Then, I apply the filleting material or tack weld and smooth it out with a gloved finger. If a tack weld, then I just smoosh into the seam.
Next, I pull the tape up (you do this right after the material is applied. Don't let it cure before removing the tape!)
Finally, after you pull the tape, you'll have just a small "step" in the fillet. I gently drag a glooved finger over it again to flatten that step. Seam come out looking very clean.
The bag and tubes also work good. It's just a matter of what makes the process easiest and enjoyable for you.
Posted: Fri Apr 13, 2007 10:39 pm
On the freedom I am building I am using a large cattle syringe it wks well
