Falcn
Posts: 66 Joined: Sat Sep 10, 2011 7:06 am
Type of boat I like: Solo open canoe
Post
by Falcn » Wed Nov 30, 2011 5:21 pm
Photo update:
Building the new foredeck.
Strips of oak hot glued to a plywood base and then epoxy filled joints. The epoxy has graphite included which makes it black
To get a slight convex bow I set the oak strips on a form
The surface epoxy has now been sanded off leaving a nice little black pinstripe between the planks. You can also see I used a white wood for the centre plank.
The sanded foredeck
The main foredeck completed. I now need to put a raised back onto this and finish shaping it to fit the hull.
surfman
Posts: 229 Joined: Tue Apr 25, 2006 3:00 pm
Post
by surfman » Wed Nov 30, 2011 5:27 pm
Very Slick!
Tight Lines, Steve
goanywhere
Posts: 374 Joined: Wed Mar 30, 2011 7:20 am
Type of boat I like: Fishing SOTs.
Post
by goanywhere » Wed Nov 30, 2011 5:44 pm
Wow! That's very nice. Will be spectacular when you're finished.
Posts: 4916 Joined: Fri Jun 18, 2004 8:14 pm
Post
by jem » Wed Nov 30, 2011 6:03 pm
Very nice!
Manjimike
Posts: 146 Joined: Fri Aug 25, 2006 7:28 am
Post
by Manjimike » Wed Nov 30, 2011 6:59 pm
Falcn wrote: Maiden Voyage photo report ...
Are they UK canals you're paddling on?
I've walked quite a few in the Marple area.
Manjimike
Post
by Manjimike » Wed Nov 30, 2011 8:11 pm
I was just over the hill from you in May this year
rodot
Posts: 205 Joined: Tue Jan 05, 2010 8:56 pm
Type of boat I like: Okwata kayak
Post
by rodot » Thu Dec 01, 2011 12:22 am
Ditto
Roger
Okwata LC,
Northwind,
Quetico
PiratePete
Posts: 305 Joined: Fri Sep 11, 2009 6:57 am
Post
by PiratePete » Thu Dec 01, 2011 4:31 am
Falcn
Post
by Falcn » Thu Dec 01, 2011 6:26 pm
The foredeck is now finished and being glued into the boat overnight. I should be able to epoxy seal the deck over the weekend.
The finished article
The rear upstand
All ready to be glued into the boat
