Page 7 of 10
Posted: Tue Oct 07, 2008 1:14 am
by Bemm 52
Matt............the cutouts give me access inside the hull again :lol: :lol:
What are your thoughts on putting scuppers in the two back corners of the cockpit............I'm thinking 1/2" fiberglass tube I just happen to have lying around. :roll:
Do you or any of the guys have any thoughts? 8)
Posted: Tue Oct 07, 2008 6:43 am
shouldn't be an issue. Scott does it on his SOTs.
Posted: Tue Oct 07, 2008 7:46 pm
by scottrunnr
Paul,
follow this link within the JEM site to see how I installed my fiberglass tube scuppers: http://jemwatercraft.com/forum/viewtopi ... c&start=60
Go about half-way down the page. I hope this helps (assuming you need any help :wink: ).
Posted: Wed Oct 08, 2008 1:38 am
by Bemm 52
Thanks Scott given me some ideas 8)
I thought I was nearly finished :oops: ........But I guess its not over until you are finished :shock:
PS really like your single you recently completed
Cheers Paul
Posted: Sun Oct 12, 2008 1:45 am
by Bemm 52
After being inspired By Olsnappa.s launch I pressed on this weekend
Scott decided against extra scuppers............ :(
as I .......just .....want .....to.....finish :) :shock: 8) :P
Handle Finished
Posted: Sat Oct 18, 2008 11:58 pm
by Bemm 52
Got first coat of graphite on hull 8)
I have cut ply out and filled transducer shoot thru hole with thickened epoxy
Question will transducer shoot thru graphite?? :? :?
Scott I noticed on your Blue fin build you must have masked this area before you graphite coated :shock:
Is there a reason for this :o
Posted: Sun Oct 19, 2008 9:00 am
by Flump
G'day mate.....she's looking good. There's no worries about the transducer shooting through the graphite mix. I've got a Garmin 140 and thats fine through two layers of glass, ply and three coats of graphite epoxy :D
Posted: Sun Oct 19, 2008 7:42 pm
by scottrunnr
That's amazing Flump that your fishfinder will shoot thru the ply. I was told by the manufacturer of my fishfinder (Eagle Cuda) not to shoot thru ply or graphite. Especially not ply. That's why I taped off the transducer cut-out area when applying graphite.
Posted: Mon Oct 20, 2008 2:43 am
by Bemm 52
Flump wrote:G'day mate.....she's looking good. There's no worries about the transducer shooting through the graphite mix. I've got a Garmin 140 and thats fine through two layers of glass, ply and three coats of graphite epoxy :D
Scottrunner quote
"That's amazing Flump that your fishfinder will shoot thru the ply. I was told by the manufacturer of my fishfinder (Eagle Cuda) not to shoot thru ply or graphite. Especially not ply. That's why I taped off the transducer cut-out area when applying graphite."
Two conflicting opinions.........maybe transducers work better in the southern Hemisphere?? :shock:
Flump and Scott thanks for answers.......I think I'll take cautious aproach and not graphite cut out... my sounder is pretty entry level so I dont know how powerfull it is :oops:
Posted: Mon Oct 20, 2008 7:46 am
I thought I posted this before.
Will shoot through graphite - no problem. :D
