Page 7 of 8
Posted: Wed May 28, 2008 12:25 pm
I built a canoe with sealed bulkheads and it was stored outside for 5 years. Tree fell on it and cracked it. It was an experimental design from el cheapo ply so I ended up chopping it up.
When I cut the bulkheads open, dry as a bone with no damage.
But, it's such an easy thing to install a tiny vent hole, it's worth the time for a little extra reassurance.
now I will say this: If you're going to seal the bulkhead with no access hatch, then DON'T drill any hole.
Posted: Wed May 28, 2008 4:51 pm
by coogzilla
Suppose you could poxy a fitting and put pressure guages in to
moniter any excess pressure causing imminent explosion. Really!
Coogs
Posted: Wed May 28, 2008 5:49 pm
by Earvin
Kayak Jack wrote: My thoughts are that, as I pack up in a cool morning, then it heats up during the day, it will build pressure. It will then either leak or be forced to oil can.
After opening it sometime during a warm day and resealing it, it will contract as the day cools into evening. It will then either oil can again or be forced to suck in air.
Can someone explain what is meant by 'oil can'
By the way JT that's a mighty fine job you have done there.
Posted: Wed May 28, 2008 6:01 pm
when a wide flat panel of the hull flexes in because it's either too thin or doesn't have enough support.
They flex like the bottoms of the old style oil cans.
Posted: Wed May 28, 2008 6:20 pm
by Earvin
Aaah. Thanks Matt.
Posted: Wed May 28, 2008 8:19 pm
Sorry, Earvin. The small hole as Matt suggests - in a compartment that will have a hatch - will assure no pressure differential. One could even put a pipe cleaner in it so water would be repelled, but air would freely go back and forth.
Posted: Wed May 28, 2008 8:37 pm
by jt
Jack,
Similar to the pipe cleaner, I was wondering about placing in the hole a small rubber membrane with a pinhole in it--like a small balloon or something--that would be almost watertight, but release the air pressure (whatever amount) that built up. Could possibly be glued/gooped in (I saw that term in another post on southern paddler where someone made a waterproof camera case and used the thumb from a dishwashing glove "Gooped" in--I'm not sure what Goop is, though???). I might actually use the glove (not the whole thing
--just a fingertip) to try--I'll just tuck it up next to the side under the gunnel to hide...
Just googled Goop
http://www.amazinggoop.com/amazinggoop/index.html
--it should work...
Also, thumb/camera case idea was from Joel F. aka nobucks
http://www.neilbank.com/phpBB2/viewtopic.php?t=4585
Posted: Wed May 28, 2008 8:59 pm
Sounds a lot like a water lock for making home brew. That's another whole thread. Get these guys going on that and we'll be here all week!
Posted: Thu May 29, 2008 10:33 am
Recipes section on southernpaddler ... Moonshine Wine , some good stuff.
http://www.neilbank.com/phpBB2/viewtopic.php?t=136
Posted: Thu May 29, 2008 4:16 pm
Sorry, Matt. Snuffy Smith and Li'l Abner just checked in.
