Re: Bluefin SS&G
Posted: Sat Apr 05, 2014 8:17 am
Thank you for showing your builds! Very impressive!
I've finally made templates for the four panels that makes up the hull. I've used the templates to get the correct shape on the panels that I've glued.
Before vacuum bagging, I started by repairing the tear-outs and knock-outs from the planer.Then I laminated the first set of panels using a weight of 160 gram/m2. After the weave followed a layer of release ply, a very thin film with tiny holes every 8 mm. The hole stack was covered with breather cloth and finally plastic. The bag was sealed with duct tape and the vacuum was applied
The tiny dark dots that you see are excess epoxy that is squeezed out through the small holes and then get trapped by the breather cloth. After 36 hours under vacuum, I cut the bag and found a laminate of very high quality - I'm very happy with the result!
/Fredrik
/Fredrik
