Sorry I'm late. Guess I didn't check notify of reply on my last post.
First let me give color objectives:
1. Although you color wood, wood grain comes through for visual appealing effect.
2. Avoid weight of paint. Weight of dye is miniscule.
3. Specific to this yak, University of Hawaii colors.
Poque says:
If one were to use this information, your best bet would to be to color the wood before tacking, joining or anything else that involves epoxy
I agree completely. I didn't get on this bandwagon until I had done the butt joints. Fortunately after applying only fibreglass splice butt re-inforcement on one side, I recognized I should leave off outside hull splice until dye was applied. So if using wood dyes do them first as pogue says.
Pics (will come later) show epoxy sploches before I corrected some of them.
Note on red panel I had applied glass splice. It won't color up.
Two potential fixes. Dying glass when covering outside hull. OR ... Using epoxy dye.
I'll test glass dying solution, but think it will bleed just like wood. Not sure how you would get the dyed portion properly positioned anyway.
The dye in the epoxy itself should work as poque says..but I believe it will act like paint and block out wood grain. I can live with that in stitch holes and small section of this panel as it will be near waterline. We will see.
poque thanks for the tint source.
AL
I take it you want 2 colours to butt up against each other?
Yep. And due to complexity of doing colors have chosen to do separate panel colors as you also spotted as a solution.
Have you considered the dye you're using & a pinstripe to cover the bleeding?
Yes reflective tape stripping. But you never know how wide bleed will be.
Given that the dye is water based I don't see how you can stop the bleed without buggering yourself for the 2nd colour.
True enough. Why I went with separate panel colors
You could try scoring the outer layer however this will probably weaken the boat (Mat will know).
Can you use a different solvent with the dye? something that won't soak into the wood as easily?
Going to pass on those thought, but thanks for your ideas.
Mick & others I'll be adding more cross panels this week,
But man does not live by building boats. Gotta fish once in awhile.
