I gave it one more quick sanding tonight and then wiped it down with acetone to remove any debris or oil off of my hands.
I then laid the glass over the deck and let it set there for a few minutes and then I smoothed over it a few times with my hands to remove any wrinkles.
For the first time builders.
When you lay the glass across your hull you will think, there is no way that this will turn transparent. Believe me I thought the same thing when I built the Pirogue, but when you start laying your Epoxy it will magically disappear.
here it is with the glass and the first coat of Epoxy. I am very happy with the deck.
