Page 2 of 3
Re: BUMBLE BEE LAUNCH
Posted: Thu May 28, 2009 8:16 am
by Tor
Hi Preacher,
I like those pulleys for the anchor set up, where were they from?
Tor
Posted: Thu May 28, 2009 9:57 am
by preacher
Tor wrote:Hi Preacher,
Tor
A walk in visit to West Marine in Mesquite, Texas. They are a little pricey at about $20 each but they are smooth with no skpping. I believe West Marine is pretty large and may have a web site.
Posted: Fri May 29, 2009 3:37 pm
preacher wrote:
What are these? They look like Joey's darts for his blow gun.
Posted: Fri May 29, 2009 4:32 pm
Used for catching Catfish. We use jugs , those folks get fancy.
Posted: Sat May 30, 2009 12:46 pm
Well, I guess, then, I gotta ask the next question. HTH do they catch one of those slimy bottom feeders? (Catfish, not lawyers)
Posted: Sat May 30, 2009 1:20 pm
Kayak Jack wrote:Well, I guess, then, I gotta ask the next question. HTH do they catch one of those slimy bottom feeders? (Catfish, not lawyers)
Same as with Lawyers , CHOW but in the catfish's favor .. with a hook attached. You use from one to a string of hooks , bait them and toss it out , the line unravels by its own self. When a cat is on there then the pole will either stand upright or if already upright , dance around and move so you know something is on it.
The same thing as with a jug. the jug just sits there , nothing , if it is upright or dancing ( Up and down ) and moving , supper is on the line. At this time you invite the guest of honor aboard the boat and home with you where you introduce him to coating of corn meal , then frying pan , some hush puppies or corn fritters , grits or beans and a cold beer. Sometimes all of the before mentioned goodies.
Posted: Sat May 30, 2009 3:22 pm
by footonthesea
Nice looking boat. The hull paint with bright deck works great and the customizations are integrated beautifully.
Congrats.
Can someone explain why it is favorable to have the anchor line on a trolley? Is this just to set the anchor at the stern or bow but retrieve from the center? Also, did someone mention using their trolley to troll?
Cheers.
Posted: Sun May 31, 2009 5:46 am
by preacher
Stakeout poles. Use them with the anchor trolley to hold your boat on a spot in shallow water without worrying about an anchor. The trolley allows you to move the position of the stakeout pole related to your boat to give you the best casting angle.
I build them out of 6 foot X 1/2 inch fiberglass electric fencepost and noodles. These 10 Red, White and Blue, went to help out HOW (Heros on Water).
Posted: Sun May 31, 2009 10:18 am
Thanks for the straight answer.
Posted: Sun May 31, 2009 10:59 am
by preacher
I have encountered my first wood boat problem. The through hull bolts on my foot braces pulled through the thin side walls. I was afraid this would happen, when I mounted the foot braces I saw the wood indent pretty easy.
Now for the remedy . . .
Stainless steel parts of course. Oversized the holes, fill with resin and wood flour mixture, then redrill to normal size. Now, maybe, use fender washers?
I also experienced some hull flex under my narrow seat pedestal so I removed the bottom of the pedestal and replaced it with a hull width piece of 1/4 inch plywood with the grain directed across the hull. I again mounted the whole apparatus with industrial velcro so I can remove and/or adjust the seat position. Worked out well this week end.
Back In Action!
Followed a friend's instructions, amazingly simple work. Over sized the holes with a drill, filled with resin and wood flour mixture, let cure for a day then sanded down and redrilled to bolt size. Remounted with stainless steel fender washers to avoid a repeat. Came out strong and solid.
Also, mounted a depth finder with transducer inside the front hatch.
I am now ready to do 8 days of serious salt water excursion and fish catching at Corpus Christi, Texas coast starting next Friday.
