I found a problem on boat #1 today. The hull is not straight on the center line. In the center on the bottom piece joint, it is bowed 5/16". This is in about 30 inches. It is an even bow, equal on each side of the bottom panel splice.
I checked hull #2, and it has about 3/16" bow in the same place. It's a little funny that I spent 3 days assembling the panels for boat 1 and part of 1 day doing the same work on boat 2! Boat #2 is the straighter boat. I tried blocking up under each boat to try to take the bow out. Boat 2 with the 3/16" straightened out perfectly. I think the 2 layers of fiberglass on the bottom will hold it in place. Boat 1 was a different story. I could lift the boat off the sawhorses and still not eliminate the bow, so I decided to take more drastic action. I cut a sawblade width out between the bottom panels for about 16 inches each side of the panel splice, where the bow was centered. I then blocked up under the center of the bowed panels, and it lined up fine. After gluing it back, I think this cured the problem on this boat.
I started to do it the same as the other boat, but I was using my drill as a weight to hold the panels aligned on boat 1. Not much of an excuse not to fix it right. I am still debating doing the same as I did to boat 1. I have already decided to stop rushing and let these boats get finished when they are finished. I would appreciate any suggestions or opinions on whether the fiberglass will hold the hull straight on the boat I did not cut and reglue, it is only bowed 3/16", and is completely straight with the blocks under it. It is bowed in the same place as the boat in these pictures. In reality, I don't think that this bow would make any difference. Even the worse boat would not have been a real problem, but I want them as good as I can make them.
Jack, I really like your idea of an ejection system for the batteries. Maybe something Air Force surplus would work.
