Thanks for all the advice.
Do not put too much weight on an epoxy joint
the weight was only to keep the joints flat, my carport floor isn't flat for the whole 18 foot+ I needed for the panel
I shall be using the plastic pipe clamps as I have a fair amount of pipe from various projects
and you are quite correct seeing the panel unfold and give that first glimpse of what the canoe is going to look like is quite amazing I only wish there were more hours in the day to finish her in one session...
here's the mid panel in place
no I don't have a helicopter to land on her...
however the day didn't go all my way, I found that I hadn't cut the permanent frames correctly
. I was never sure about these frames (seemed to flimsy) and may try to do them another way to make them a bit more robust. It may add a little weight but I think you'll all agree this was never going to be a one man boat.
and another thing don't let the cup you've been mixing your resin in sit on you panels and cure...
Until next time then.
