Houston Wadefish Progess
Mullet_Key
Post by Mullet_Key »
Going well, missed working on it this evening, expect to really pour it on this weekend. If the hull panels look a little dark it's because I gave them a very, very light coat of epoxy before I started. I want to minimize saturation when I glass. MK
http://i158.photobucket.com/albums/t94/ ... panels.jpg
http://i158.photobucket.com/albums/t94/ ... Panels.jpg
http://i158.photobucket.com/albums/t94/ ... frames.jpg
http://i158.photobucket.com/albums/t94/ ... oframe.jpg
Pygmy Arctic Tern
JEM Swamp Girl -15
JEM Wadefish 15
dangermouse01
Post by dangermouse01 »
MK;
Looks great!
paddling4sharks
Post by paddling4sharks »
Mornin';
Looks good. Can't wait, Matt has the plans for my "Hoot-a-gator 8.14" :lol: in the mail. Hopefully get to start this weekend.
Mullet_Key
Tumblehome Panel Up
I've installed the top-most TH (tumblehome) panel. Once they were all level and true I began spot welding from the center seam working my way up the hull. I've spot welded the TH panel and will begin pulling those wires out too. Meanwhile, I've been working on the cockpit and tankwell.
http://i158.photobucket.com/albums/t94/ ... pStern.jpg
http://i158.photobucket.com/albums/t94/ ... -2-Bow.jpg
I led an outing with the kayak fishing club this past weekend to Smith Point, TX. The NW winds blew 3' of water out of the bay leaving all the good fishing spots high and dry. We'll come back later in the summer.
Pygmy Arctic Tern
JEM Swamp Girl -15
JEM Wadefish 15
Mullet_Key
Glassed the hull this weekend..
...now the fill coating starts. Going pretty good. Filled in the voids between the panels, the numerous wire holes. Had a friend over to help glass the hull. I'm missing the spring bite!! :x
http://i158.photobucket.com/albums/t94/ ... Hull-2.jpg
http://i158.photobucket.com/albums/t94/ ... Hull-3.jpg
Pygmy Arctic Tern
JEM Swamp Girl -15
JEM Wadefish 15
Looking good mate, Lovely neat work. 8)
Mullet_Key
Epoxy malfunction
Had a setback this weekend with an epoxy malfunction. It was a case of timing, blending, blush, maybe humidity and did I say timing? Anyway scraped off about 1/4 lb of sticky stuff, wiped it down with epoxy thinner and applied a very light coat of precisely mixed System Three. **Good to Go!! Problem solved.
Pygmy Arctic Tern
JEM Swamp Girl -15
JEM Wadefish 15
Mullet_Key
Progress at last
A little bit here... a little bit there... I've glued the shear clamps on the inside of the hull in two long strips. I'll join the cross members by cutting a little step or sill on the ends. The inside of the hull is glassed now and I'm working to flush mount my SeaDog foot braces. That's a little time consuming for gaining about 1.5 inches of foot room in the cockpit. Photo's to follow. Some glassing left to do inside the cockpit and tankwell. Now its off to the Lower Colorado River for camping and fishing with the family and the Swamp Girl in tow. Commemorate the Fallen!! MK
Pygmy Arctic Tern
JEM Swamp Girl -15
JEM Wadefish 15
Mullet_Key
A little bit more progress
I see where natural sunlight would help my photography efforts. The recessed Sea Dog foot braces are finished, just a little cosmetic work left. Cross braces are installed.
Dry Run of all Parts
View of Recessed Foot Braces
Exterior View of Cock Pit
Cross Beams and Frame Chocks
Pygmy Arctic Tern
JEM Swamp Girl -15
JEM Wadefish 15
Mullet_Key
DM's trick of the blocking up the internal frame helped a lot as I would assemble and disassemble the parts for repeat dry runs. On the last dry run I screwed the parts to the hull with small wood screws. When I finally glue them on, I'll fill in the screw holes. I glued in some 1/2" strips for additional vertical support on the rear deck. Underside of Rear Deck
See ya!
Pygmy Arctic Tern
JEM Swamp Girl -15
JEM Wadefish 15
