Mick.
When the fish see this boat of yours coming at them, any fish with sense is going to run away or cross overland to a safe pond.
There is not one thing you forgot to include in the building of her as a fishing machine. This is a boat made for fishing, great Job.
Mick;
Just one word. SWEEEEEEEEEEEET!!!!!
Cant wait to see some photos of it on the water and in action!
Tho, I would like to see a side view photo of it in the water, just to get an idea of where the water line is, if it's not to much trouble.
And of course one with you in the boat, I have a pretty good idea of how big that smile on your face is gonna be.
What brand of seat did you use? And also the lid to your fish cooler in the cockpit?
One of us is gonna have to get busy building ours, now that your gonna be "gone fishing" all the time. (you notice how much we hear from Javier, now that he has finished up his ). Maybe I should just start my own build thread to get myself moving along.
Mick,
WOW, very impressive project!!
The drain holes instead of the scuppers is going to work very well in 99.99% of the conditions. Just a breaking 3-4 ft wave over the bow will load the cockpit well, then you'll have to evaluate the set of waves quickly and decide whether or not to continue out passed the surfzone while it drains. Who thought of the drain holes? No scuppers holes will make it faster, lighter.
In your first trial check the clearance of your paddle stroke in relation to the front-mounted rod holders. You may need a paddle about 240cm long or more with such a wide beam. The paddle will be an important thing to match-up with this kayak so try-out as many of the latest designs you can find.
I'm no fan of sails on kayaks, but you may want think about it for the future after a season using it just with a paddle. I didn't see paddle holders in these pics, maybe you are still outfitting.
We're looking forward to more pics with your fish stringer loaded.
Take care,
Craig
Sabalo
Take care,
Craig
Sabalo
Hi guys,
Thank you all very much for the nice and positive comments.
Weather was appalling yesterday so I took her for a test run in the local weir. Wind was blowing S.E. 25 - 30 knots with rain and drizzle qualls and wind was tunnelling down the river at significantly more than 30 in gusts.
I have very little experience of sit on top kayaks, so the only comparison I could do was with my very quick sit inside jobs.
Here are my initial impressions of this boats performance.
INITIAL STABILITY - pretty good, certainly better than I expected.
SECONDARY STABILITY - outstanding. I was able to lean the boat into turns effortlessly and maintain the lean and controlled lean turn for as long as I wanted.
WIND SIGNATURE More than my sleek little SIKS but I expected that. Still acceptable.
MANOUVERABILITY - excellent. With the rudder up and a little pace on, I was able to turn the boat through 180 degrees with a single low brace or stern rudder stroke. She is way more manouverable than any of my SIKS.
SPEED - It was hard work paddling up wind into 30 plus knots but then again, that would have applied to any kayak. I was able to make reasonable progress though and punching into the wind chops there was no noticable hull slap. A very good thing in a fishing kayak.
Running down wind was something I have never experienced before. At sprint pace, I was able to get the boat up on the plane and was actually travelling faster than the wind chops This was a real hoot, and all too quickly, my down wind run was over.
While doing this, however, I was able to put her through some serious trials at speed. low brace/high brace/ lean steer, rudder up/down etc.
This is a genuine high performance SOT. I am delighted with her and can't wait to get her into some more challenging open water conditions. She tends to weathercock a little with the rudder up but when it is deployed - no problem.
SUITABILITY SURF CONDITIONS. My first impression is that I would like a little more volume in the bow and much less volume in the cockpit. The latter is easily fixed and I will be attending to that shortly. She would definately benifiet from a small skeg postioned just behind the paddler to aid in control while running down waves. A small bow scoop similar to Aussie racing surf skis might also be of benifiet. I think my scuppers/ drain holes are not big enough but will persist with them for now.
Overall, I just love this boat. There has been talk on other forums or what constitutes a superyak and what doesn't. For my needs, I believe this boat easily falls within the Superyak category and will do me just fine.
Craig, mate thank you very much for your well thought out comments. Re water in cockpit, I plan to significantly decrease the volume of the cockpit so that when I am in her, there will be little room for water.
re the paddle, My paddle of choice is a SKEE brand expedition sea kayak paddle, 230cm that seems to work very well on this boat.
Re the sail, I have one on one of my expedition boats and will be installing mounting points a bit later.
Re the front rod holders. They do interfere with the forward paddle stroke somewhat. For extended travelling or surf work however, they are easily removed and stowed in one of the hatches. They are more meant for slow trolling small lures or live baiting when paddle performance is not so important.
Re the paddle holder, Still not sure about wher to put it, if at all. Traditionallu, I have just let the paddle rest across my lap in case I need it quickly.
Mick,
Obviously you have tons of experience and skill, you know what you're doing.
But, please hold off on the cockpit volume decrease idea until you test getting into the cockpit well during a wet exit. You may realize that you need that volume to re-enter safely.
The kayak fisherman often sit 90 degrees perpendicular when fishing in a drift. We also sit perpendicular scooting-up to the front hatch to access the gear to set-up after getting passed the surfzone.
Keep the volume you have for a few months at least is my strong recommendation.
I love my large volume cockpit well because I can get into positions to relieve my sore rear-end from sitting 4-5 hours straight.
Craig
Craig
Hi Scott,
Re the side drains. I don't know if they are better or worse than vertical scuppers. They seem to work efficiently enough but in the conditions I was in I was unable to actually bury the nose or sides to actually take on enough water to properly test them.
My comments re the volume in the bow were based on she seems to ride just a little low in the bow. But that could have been because I am sitting much higher in this boat than I am used to.
The final coats of resin are on now and I will be giving her a much more substantial trial in the next day or so. Just looking at the shape of the bow and the volume that is allready there, I think it will be fine.
Hi Craig, Thanks mate
I started making a centre console yesterday that would take up most of the 'excess' volume and pretty much the same thoughts occurred to me.
I just got a report last night that the school and spotted mackeral have showed up in numbers in Hervey Bay with a few Spanish mackeral thrown in so i am flat out at the moment sorting tackle and stuff. If I can nail a Spaniad of say 18 or 20 kgs I reckon it will be a pretty good test
