starting a TV 15-32 in SC
Just got my plans and have started cutting patterns out of sublinoleum ply since I have a 16 x 4 marine ply I had already scarfed and glued for other project. I built a Cajun secret and its a nice piro. I just liked what I read and saw with the TV. Ron's posts were major influence. Hope I can do has good a job. Bill
- Type of boat I like: All boats
Re: starting a TV 15-32 in SC
I'm looking forward to seeing this build. I have long considered the TV, and will probably build one after I finish what I am working on now. I have the plans for both sizes of the TV.
Terry
The frames are all loosely attached now. I was thinking of putting two 2x4s along the tops of the frames so I can flip it over at this point to tighten and trim the fit before putting on the second set of panels. A backwards strongback I guess. Any potential issues with doing that? ie are the tops of the frames supposed to be in the same plane? I realize it could affect rocker but I will be able to take them off when putting on the second set of panels which really set the rocker at that point.
- Type of boat I like: Laker 13 Laker14 Okwata
Very nice. I may do a TV this fall.
Looking good Duck.
Thanks guys. I am enjoying this build very much but have had a lot of other projects going on.
Put cloth on outside yesterday
and applied first coat
Boat is starting to look bigger...
One question I have is if you put fore and aft decks on, how should you make the transition of outside rubrail (at the gunnel height)? just start and end at the decks? I have not seen anyone go all the way from bow to stern but maybe I missed it. and what size should it be? thanks
