New Stalker Build
Re: New Stalker Build
Very impressive.
I've decided I really need to paint the upper hull with something which will cover the epoxy with a solid color. Any advice on the paint types to look at?
I used a marine grade poly-urethane enamel it covered the uh ohs pretty well.
Tight Lines, Steve
- Type of boat I like: Okwata.
I used a paving paint and seems to have worked pretty well.
Simon
"It is better to travel well than to arrive".
A long time since any update, I have been busy though.
All the construction has been completed except I've decided to build in some flotation at the front. I will be adding a watertight bulkhead and access hatch under the foredeck.
The canoe is now being painted. I've laid down 4 coats of 'Oxford Blue', and four coats of 'Cream'. At the moment the last coat of cream is drying so the masking tape is still in place. I also gave the foredeck its first coat of clear varnish too.
Still to do -
Paint a metalic bronze pinstripe between the blue and cream.
Touch up the black (graphite epoxy) on the bow.
Another four coats of varnish to the foredeck and gunwales, seat and kneeling thwarte.
Finish the inner hull after fitting an airtight bulkhead in the bow for additional floatation.
Still to do -
Good Narrow boat colours
Looking good
Cheers Mike
Looking good
Cheers Mike
Finished paint job (bow shot), so what do you think?
- Type of boat I like: the Laker freedom strip
Looks great nice job!!!!!!!!
