New Stalker Build
Coal
Type of boat I like: recreational canoe
Re: New Stalker Build
Post by Coal »
Very impressive.
Falcn
Type of boat I like: Solo open canoe
Post by Falcn »
I've decided I really need to paint the upper hull with something which will cover the epoxy with a solid color. Any advice on the paint types to look at?
surfman
Post by surfman »
I used a marine grade poly-urethane enamel it covered the uh ohs pretty well.
Tight Lines, Steve
Earvin
Type of boat I like: Okwata.
Post by Earvin »
I used a paving paint and seems to have worked pretty well.
Simon
"It is better to travel well than to arrive".
Falcn
Post by Falcn »
A long time since any update, I have been busy though.
All the construction has been completed except I've decided to build in some flotation at the front. I will be adding a watertight bulkhead and access hatch under the foredeck.
The canoe is now being painted. I've laid down 4 coats of 'Oxford Blue', and four coats of 'Cream'. At the moment the last coat of cream is drying so the masking tape is still in place. I also gave the foredeck its first coat of clear varnish too.
Still to do -
Paint a metalic bronze pinstripe between the blue and cream.
Touch up the black (graphite epoxy) on the bow.
Another four coats of varnish to the foredeck and gunwales, seat and kneeling thwarte.
Finish the inner hull after fitting an airtight bulkhead in the bow for additional floatation.
Manjimike
Post by Manjimike »
Good Narrow boat colours :lol: :lol:
Looking good
Cheers Mike
Falcn
Post by Falcn »
Finished paint job (bow shot), so what do you think?
rodot
Type of boat I like: Okwata kayak
Post by rodot »
Excellent job, great colour choice.
Roger
Okwata LC,
Northwind,
Quetico
surfman
Post by surfman »
I like it a lot!!
Tight Lines, Steve
toolman
Type of boat I like: the Laker freedom strip
Post by toolman »
Looks great nice job!!!!!!!!
