TV 15-29 strip build
woodman
Type of boat I like: plywood kayaks
Post by woodman »
Well finally caught up on work and..... Another score of more cedar lumber "free" 4 pcs. 3 3/4'' X 6 1/4'' X 11 1/2 foot long.
The forms....
The table saw setup along with doing a cove and bead this time..
woodman
Re: TV 15-29 strip build
Post by woodman »
Forms are in place 20'' spacing...Instead of laying the panels out on a flat surface I'm using the forms. I will just pop them off when glued up and trimmed then run them through the sander, tack them back on the forms then glue them together....
woodman
Post by woodman »
With the bottom panels glued up I ran a couple of rows on the sides and marked the underside of the bottom panels to be trimmed off.
Bottom panels sanded and tacked back on the frames..
I don't worry about trying to color match below the water line it gets graphite coated...
woodman
Post by woodman »
The sides are almost done...
woodman
Post by woodman »
The sides are glued up and marked on the back side to trim the top edge...
These strips were used as the reference point to mark the sides to line up with the top side panel..
woodman
Post by woodman »
Sides sanded and tacked back on and the bottom panels are glued together in the center...
The bottom is glued to the side panels with thickened epoxy...The ends are finished off like this..
woodman
Post by woodman »
I am wondering...if the tumblehome panels are attached now will it be hard to get the fiberglass cloth to adhere to these without falling back, or should the cloth be taped back up inside to keep it from sagging?
trim the glass while it's dry so there's about 1" hanging past the gunwales/sheer. The epoxy will hold it in place. Or you could always apply the glass in halves and rotate the hull so the tumblehome panel is vertical.
woodman
Post by woodman »
Thanks Matt ...my cloth is 52'' wide I will just do the one pc.
woodman
Post by woodman »
Now another challenge...
