Between laying out my shop and trying to get some done on this boat I havent posted to many pics.
Well here is a few.
Bulkheads built glassed and fileted in
started gluing the shear strips. That sure does start shaping the boat up.
Here is a close up of the seams , they still need a little sanding
same area wet down with water
and backed up to show some of the color of this boat.
After a saturation coat I will go back and match the color of the different areas filling in the stitch holes.
Thats it for now.
SS@G Northwind
Re: SS@G Northwind
Sorry Matt for changing your decks I already had it cut when you said some thing.
I had a pretty good day on the Northwind today.
Got my decks layed out ,glued up and planed . Have them tacked down and rough cut.
These are the dropped nose balanced de3cks I like.
she is really starting to shape up
she came out with about the look I wanted
Thats all for now.
Thats all for now.
Re: SS@G Northwind
Got the decks pulled and the back side glassed
block glued in nose and stern
tabs on bulkheads glued on
Re: SS@G Northwind
I got to wet the whole hull down today and I sure like her looks and lines.
Like Darrel says wetting her down all the way gives you and i deal of how she will look.
Be a few days before I can get back on her.
Hull is still light
Hull is still light
Re: SS@G Northwind
The stripped panels really make a difference to this design. This plus the way the panels are joined without visible filler makes it hard to tell it is SSG as opposed to a straight out strip build.
Job well done Ron!
Job well done Ron!
Re: SS@G Northwind
Ya'll check out all the boat building wood nailed upright on those 2x4s in the back of Ron's yard. How many boats would that build?
Bob
Bob
Re: SS@G Northwind
Well I have been stomping cussing and throwing a fit because its been to cold for the epoxy to set right and so much pollen in the air that if you had wet epoxy outside it would look like a green wooly worm in about 15 min.
Got off my backside and built a boat tunnel untill I can get my shop built. the plastic catches more heat so the epoxy worked really well today.
I put the Northwind in the tunnel and gave her a coat of epoxy to seal everything and have the color so I can start matching and filling the holes for the stitches.
Epoxy sure brings out the colors.
Re: SS@G Northwind
Precoat on
Got holes filled and the hull sanded again , be ready for glass and cloth shortly
