G'day Harold, and welcome aboard mate.
- and thanks for the kind words and the questions. I try to contruct my build threads sort of like a "how to" or how not to as the case may be in the hope that they might be of some little use to budding builders and really appreciate the fact that they might actually help somebody.
I am no master boat builder but my methods are pretty simple and they seem to work OK for me. Will try to answer your questions as best I can.
1. Are the tacks the sutures that hold the panels together, i.e. you've got all panels in the top and bottom of the boat sewn together with wire stitches until you align them and glue them together?
The
stitches are the wire ties I use to temporarily hold my panels together while glueing. The
Tacks are a mix of epoxy resin and woodflour (sawdust) that I put between the stitches as the start of the glueing process. (The whole process is well explained in the tips and tricks section of this forum.
All the stitches do is hold the panels in place till the tacks set up.
http://jemwatercraft.com/forum/viewforum.php?f=7
I have modified my methods a little to better suit my whims but can thoroughly recommend the methods as stated by Matt. They work every time and are probably stronger than mine.
2. Is filleting the gluing together of the panels, or what? I didn't have a clue on this. It will take me some time to learn the terminology. Its completely foreign to me! Is there a dictionary of terms on this nautical site?
In the truest sense of the word, as I understand it, "Filleting" means the epoxy and woodflour mix used to re-inforce the glued panels on the inside of the hull. It also creates a concave and rounded surface over which the fibre-glass is more properly applied. Out of lazyness, I call the application of wood-flour anywhere filleting.
Mate as far as I know, there is no dictionary and the meaning ofmost of the terms we use here will come soon enough. I had to learn to understand American
and re-learn feet and inches when I started. Now, I just don't bother. I just measure everything in metric. (much easier) The trick to it is to throw your standard tape measure away, get a good metric only tape and measure from the specs in the drawings. You will be surprised how quickly you can pick it up. (probably take about 5 minutes)
3. With all of the panels, you push and mold them into the form you want, the form shown on the blueprints. How are the wedges helping in that process, and are they sticking through the bottom of the kayak???? What are the wooden straps with screws; anything other than a method to hold both main top panels and the rest of the panels together so they won't move?
Mate, that is a very perceptive question.
The panels holding the wedges are the bottom panels, and the wedges are placed in the centre, longditudinal seam. When these panels are marked out, they are allmost, but not quiet straight along most of the length. Unfortunately, my eyes are not as good as they could be, so my trimming of the panels is not quite as accurate as it should be.
When the panels are stitched together, and the hull inverted, I ALLWAYS run a very critical eyeball along every seam in the boat, looking for any wobbles in the symmetry of the thing. Each and every panel joint should have a smooth, even curve along its length. Where the panels have had a little too much trimmed off them, the tie wires pull them together too tight and this causes a dip in the curve of the seam. The only way to overcome this, it to loosen the tie and wedge the panels apart a little to achieve the curve required. The gap can be easily filled with epoxy/woodflour and it will not affect the integrity of the hull.
Likewise, sometimes, not enough has been trimmed off the panels and this will cause a high spot in the seam. the ties need to be cut in that area and each panel needs to be gently sanded so that the high spot dissappears. Often I have stitched and tacked the bottom seam several times and had to cut some of the tacks and re-work them to get the lines that I liked. I had three attempts on the bottom seam of this boat. (Don't use a jig or sabre saw for this. The panels will bind on the blade and break)
I use a hacksaw blade and hold it so that it cuts on the up stroke.
That's my questions for now, but I can guarantee all of you there will be more!!
Mate, Ask away!! this is the whole purpose of this forum. Many of the guys here are way better builders than I am and I have learn't just about every thing I know about this caper from them.
G'day Snapps,
Thanks mate LOL
Too old and waaaay to mean to let that interfere too much with my all consuming passion for building these things.
Got a little done today before the Honey Do stuff over-ruled me.
While the decks were stitched to the hull and stable, i marked and cut the holes for my hatches.
I use a modified hack saw blade for cutting the real tight curves.
Decks are off and started the prep work for the interior fillets. the masking tape ensures nice clean lines along the fillet edges. Harold, I will post a step by step thingy on this for you when I get to it.
Temp frames/bulkheads are out of the hull, and allmost ready for epocy and fibreglass on the inside.
