Now you know the other half of the story.
As we use to say in the service there is the right way and then the service way , now we have changed it to Jacks way and the correct way. Now at times he does get it right but as they say , Even a blind Goose will find some corn.....Then we have to agree with him ..Kayak Jack wrote:As I said, others may differ. What I forgot to add is that - if they do differ from my opinions, they are wrong.![]()
I would have to say that this is probably your best bet. Air pressure is a complex thing. Just make sure you only put one hole, that will allow air to flow in or out as temperature changes but if it were to submerge, no water would enter the chamber (Same as pushing a glass under water invereted, if there is no other port for the chamber to equalize then the water cannot enter.jem wrote:A small, 1/16" hole at the very top of the bulkhead will relieve any pressure and won't be big enough to let much water in if you capsize and that part of the canoe is submerged. It'll also be hidden from view.
If you add that hole, drill a 1/4" hole first, file the hole with epoxy-woodflour mixture, let cure, then redrill with 1/16" bit. That will seal the grain.
