Love the lines on her, Matt
Look forward to when it becomes available.
Cheers Mike
Dan's Pelagic
Somehow this didn't take on my first post attempt. ( I could have closed window in Preview?)
While waiting for the dye (it's arrived), I tried doing some stitching with the cross sections to the panel strips using the #1's.
I thought the first two looked OK.
But they don't really lineup.
I'm pretty sure my placement measurements are OK. I'll check them again.
But what else could I be doing wrong?
Dan;AlohaDan wrote:But they don't really lineup.
Are you wondering why the horizontal and vertical lines drawn on the first frame are not parallel with the ones drawn on the second frame (shown in your last photo)?
Just two panels stitched together is still pretty flimsy and twisty. The more panels you stitch together, the hull will become more stable & ridged and that twist will start to work itself out. Then it will me a matter of loosening & tightening stitches to get the last little bit of twist out.
But if that is not what you were questioning, please clarify.
Matt
Here you are:
#1 is back, #2 closest.
Precisely my fear. I'll try adding a third, but it sure seems awful weird.
Manji
Matt provided it. Measures 7/16", but maybe it's metric.
Not in a position to mess around with drive at this time, but when I tack glued it for fit, anything that needed to be moved a bit was done easily using dremel.
Here you are:
Manji
Matt
Here you are:
Manji
Here you are:
Manji
I still don't quite grasp what you concern is. It's probably right in front of my face but I'm not seeing it. If you're worried the frame look a little crooked right now, that will take care of itself when you stitch on the other panels.
Can you reword? Maybe another pic with a pencil or stick pointing at the issue?
Sorry I'm dense tonight.
